George Napier avatar image
Wiring 150/50 to battery
Hi, I'm connecting a new smart solar 150/50 to my batteries (12v 1800a/h lead acid). Does it matter which order the cables are connected? +ve or -ve first? Thnx for advice ;-)
wiring
Hi @George Napier
It's best to always connect minus first, and have all switches / fuses / etc. in the positive lines.
this way you prevent that any communication wiring can have current flowing through it when a negative wire is not connected.
George Napier answered ·
Thnx for tips...hadn't actually contemplated a fuse between the +ve battery cable and the charge controller. I've actually got a 50A fuse/holder spare: would that work for the battery/controller I've got?
warwick avatar image
warwick answered ·
I know when it comes to automotive, positive should be connected first because negative is grounded to the body.
If the negative is connected first, a spanner shorting against the body when connecting the positive could damage the battery, cause fire or injury.
But, in the case of a solar / battery setup, even bus bars, I can’t think of any practicalities that would prefer one over the other.
That means we need the electrickery gurus to advise whether there is any difference connecting one before the other.
