Hi, i want to know if i can root the T-sence wire with the battery cable (200amps Max). In my previous Job, we've learned to not root the sense wire with the Power wire.
What do you think about that?
The temperature does not contain a thermal resistor, but it contains an integrated circuit temperature sensor.
Thank you for Info, but, in this case the sensor current was not "disturbed" by the hall effet due to current in the battery wire?
Can you explain what you mean with "root" the wire in your original question?
Sorry, i made a mistake, it's route*
Thanks, it makes sense now. It is ok to route the temp sensor wires with the main battery cables. The Hall effect will not influence the temperature reading.
I think the T-sense is a simple thermal resistor so it should be safe.
At the MultiPlus Compact the T-sense wire is tied at the negative wire by default.
13 People are following this question.
