John Silver avatar image
Firmware Version 1959402
Where can I get this version?
Firmware Update Issue
Matthias Lange - Service Team Döbeln DE avatar image
The lastest version you can get for this device is 1959209.
You can get it at the Victron Professional Portal:
https://professional.victronenergy.com/
2 comments Share
Just to add, 400 assistant firmware is unavailable for 19xxyyy processors. Only 200 assistant firmware can be used with 19xxyyy processors.
You need 26xxyyy processor models to run 400 assistant firmware.
Firmware versions explained:
https://www.victronenergy.com/upload/documents/manual-VE.Bus-firmware-versions-explained-EN.pdf
Thanks for your comment and advice. I have already installed the 209 version, but even though a list of assistants come up, they all ask for a newer version. One of the assistants mentioned 402 as being a suitable version which is why I have asked the question. Why would it specifically ask for a version that does not exist??
