Is this a good practice to disable the MPPT charger while connected on shore power?
The only issue I see is in full sun while also connected to shore power, it may be possible to charge at a higher amp rate than your batteries can handle. This should theoretically only happen if your batteries are low, the sun is out (MPPTs are bulk charging), and when you plug in, your inverter starts charging in bulk mode.
As long as your batteries can handle the max combined current of both charge sources, you are fine. You could also use DVCC to limit the max current, provided you have a Victron inverter and CCGX.
I also like to set my inverter charge voltage a bit lower than my MPPT voltage, just so the sun is topping off my batteries each day, and not the grid. I hate wasting sun :)
I believe you need to use a Venus device and you can limit the combined output current to the batteries. It's under the DVCC setting, see below
17 People are following this question.
