richardp avatar image
richardp asked
Multiplus 12/800/35 Alarm when connecting VE.Bus.BMS
When I connect the Multiplus to the VE.Bus.BMS with the RJ45 it stops inverting and the alarm light comes on.
I have completed the 'van install' as per the schematic and so far everything else is running correctly.. The Multiplus works as a charger, UPS and as an inverter.
The Multiplus enabled light is on on the BMS. I haven't connected the 'Mains detect' as I don't plan to be using shore power.
Any help will be gratefully received!
Many thanks
Multiplus-II
nebulight avatar image
nebulight answered ·
Do you have the VE.Bus BMS assistant loaded on your multiplus?
https://www.victronenergy.com/live/assistants:overview_of_available_assistants#vebus_bms_support
richardp avatar image richardp commented ·
Thank you very much, Its working now. I didn't realise I needed it with this Multiplus.
