when i connect my washing machine my earth point get return supply even the earth rod get the supply tested with tester.can anyone help me in this issue?
Hi
You need to explain better? so you are measuring current flowing in the earth wire?
Do you have a neutral wire? and is the system wiring up to standard in cable sizing etc?
Regards
Rob D
NZ
13 People are following this question.
