staffie1260 avatar image
staffie1260 asked
Atlas Combi 12 / 1500 - float light constantly on
Hi, I have the above inverter/charger on my narrowboat.
For the last few days the orange float light has stayed constantly on, even when the charger is switched off or in boost or equalise phases (charged using a diesel generator).
Fairly standard narrowboat set up with 3 x 110ah leisure batteries.
Had anyone seen this issue before, and is it likely to be a problem?
Many thanks for any advice!
charger
An Atlas ?! This device is antique. :)
Is is even working properly? If yes, use it until it's broken and then you have to buy a new one.
Chargers.
