I just installed the BMV 700. I'm not getting an input reading for amp hrs. It tells me how much I'm using, but not what's going in. This is a solar set up
Thanks
Thanks
Is the negative wire of the solar charger on the right side of the shunt(loads chargers) or is it directly connected to the battery?
At the side labeled with "battery only" should only be the battery minus and nothing else should be connected there or at the battery minus.
All other negative wires must connected to the "load/charger" side of the shunt.
12 People are following this question.
