dutchy0198 avatar image
dutchy0198 asked
Victron MPPT 100/20
Hi all sorry if this has been asked a thousand times, below are the only specifications i can find on my solar panels (2x 150W in parallel) equaling:
Mono-Crystalline 300W
Max Power Voltage 18V
Max Power Current 16.6A
Open Circuit Voltage 21.24V
Short Circuit Current 18.34A
Module Efficiency 18.3%
Tolerance Wattage 0-10W
Will the 100/20 Victron Mppt charger be ok for my camping application to keep a 100ah battery topped up only really being drained by a fridge?
I keep seeing concerns about vbat +5v? its a bit over my head, is this an issue i will face with the selected controller?
Thanks in advance community.
MPPT Controllers
JohnC avatar image
JohnC answered ยท
Hi Dutchy.
Presumably a 12V batt. The 100/20 is the right choice, but I'm not sure what you've done there with the panel specs (doubled up on W and A?). Maybe a 'packaged' 300W of 2x 150W units? Fair enough.
The '+5V' thing may impinge you in low light, where panel specs go out the window. May or may not be a worry, just try and see. If it won't fire up in poor light (and you need it to), you could consider rewiring the panels in series.
A lot of these panels were really made to match up with cheapo pwm cc's. The better mppt's prefer a higher Voc to extract the most from their capabilities in poor light. I'm not suggesting you go pwm though, your choice is good..
dutchy0198 answered ยท
Thanks for your reply John! this has eased my mind a bit, i think missing out on a bit of early and late solar production wont hurt me too much, and as you pointed out (probably with the help of this forum) i could probably re-wire in series if its not working good enough.
Maybe a 'packaged' 300W of 2x 150W units? Yes mate this is correct bought as a 300w solar package with one of those infamous cheapo blue pwm's on it. The pwm may work fine i just dont want to have to worry about overcharging the battery etc because its not "smart" enough to reduce amps and voltages as the battery reaches its full SoC.
I was thinking of putting short leads (10 AWG) on both the MPPT and PWM with Anderson plugs and some Anderson plugs also in the circuit near my Aux battery so i can switch to either unit in a matter of mins if the situation requires.
Cheers Dutchy
JohnC avatar image JohnC โ™ฆ commented ยท
Both types don't read 'SOC' as such, just V's. The 'Smart' designation of the Victron (that model) refers to it's bluetooth/phone monitoring and programming capabilities. Which are impressive and comprehensive.
If you do 'switch-em-out', even just to test, try to remember to hook the batt(s) up first, before the panels. Some kit may reset it's target V's otherwise, that's all.
0 Likes 0 ยท
dutchy0198 avatar image dutchy0198 JohnC โ™ฆ commented ยท
Ok thank you, a good point to remember.
0 Likes 0 ยท
