Take a look at the LoRaWAN modul.
https://www.victronenergy.com/panel-systems-remote-monitoring/ve-direct-lorawan
You can connect this via VE.direct to your MPPT an it will send data to the VRM portal.
Hi @M.Lange and @ejrossouw,
So what I am trying to do on my project is to hook the Victron charge controller to a 5 port Ethernet to carry the data to an internet driver and from there it is sends the data over the internet through the antenna. The thing is that will the 5-port Ethernet work as the VE.Direct, instead of using the long distance internet can we just put the data on the Ethernet bus and transmit it over?
13 People are following this question.
