Can I use Multiplus 24/5000va/120amp with solar panels, I m experiencing a lot of power outage and my battery bank is not charging fully. Can I connect my inverter/charge to a solar panel
Hi K. No sorry, you can't. The Multi can only accept an ac supply to charge batteries.
Solar panels have special needs, and typically you'd select a suitable dc charge controller to suit the panel(s) you choose. Victron have a wide range, but come back if you want more info.
9 People are following this question.
