shep avatar image
shep asked
Chassis grounded loads - BMV
Just a quick simple one (I hope) before I purchase a BMV712: several auxiliary powered loads (sockets etc) in the back of my 4wd are chassis grounded (ie no individual return to negative terminal). As long as the auxiliary battery only has the shunt attached to it, with the chassis ground attached to the system side, everything should work ok right? I don’t have to do anything with the main (starter) battery which shares the chassis ground? (I’m not interested in monitoring the main battery).
thanks for your help!
BMV Battery Monitor
JohnC avatar image
JohnC answered ·
Yeh Shep, should be fine as you describe.
A bonus if you want it is V monitoring of your starter batt as well. No shunt or 'interference', just a coupla little extra wires.
