grazza avatar image
grazza asked
Battery Protect Programming
I’m installing 240ah Lifepo4 batteries in my caravan. These batteries have a built in BMS that kicks in at 9.2v, absorbsion at 14.4v and float at 13.8.
I am installing a 100 amp Victron Battery Protect for the overall caravan load
Can I get advice on the programming of correct voltages and mode for the 100amp Battery Protect.
Thx
Battery Protect
wkirby avatar image
wkirby answered ·
As you already have a BMS then I'd put the Battery Protect in LiOn mode and have your BMS control it with high or floating signal to switch the Battery Protect on or off. In this mode the Battery Protect acts rather like a relay
grazza avatar image grazza commented ·
Thx. The batteries have the BMS Built into the casing so you can not connect to the BMS itself. Maybe the Victron Battery Protect is an overkill but I was installing it as a further safeguard. I have tried programming on A2 but for some reason the system goes “to sleep” and power is cut off to the vans 12v circuit.
