@brassmonkey001 yeahhhhh I wouldn't do that if I were you... I know how easy it is to swap a plug, but at the same time I don't think it's worth the risk, because I would definitely view it as highly suspect if someone tried to file a warranty claim to me and I discovered the plug had been swapped. I highly recommend that you return the charger to your distributor and just get one with the proper plug; it's a PITA, but I think it's worth the effort to know for sure that you're covered b y warranty.
@brassmonkey001, yes, a travel adapter would likely pose the smallest PITA out of your options.
Strange about not mentioning the type of plug - it definitely should. I'm in 120vAC land so we don't carry the IP22s (they're 230 only), but a quick glance at the Victron order page tells me that they're available in 3 different plug types (CEE 7/7, UK, and AU/NZ) so I would expect a reputable distributor to either offer the option or at least specify what they're selling you :-/
9 People are following this question.
