petermcgowan avatar image
petermcgowan asked
Quattro / LifePO4 / Below freezing / Shore Power pass-through?
Does anybody know if the Quattro is clever enough to hold off on attempting to charge LifePO4 if they get too cold? (As I understand, attempting to charge cold LifePO4 is a bad idea). If not, and I turn it off, does anybody know if it will pass shore power through?
Thanks,
Peter
petermcgowan answered ·
Answering my own question(s) in case someone finds it helpful. Re:Freezing and LifePO4 > My batteries have a BMS (Battery Management System) which will handle the cold temperatures and disable charging below 25F, so I don’t need to turn off the Quattro. Re: AC Pass-through > Quattro off will kill the AC outputs if it’s turned off. Further thoughts: Although I now know I can leave the Quattro on this did prompt me to consider how I might handle the scenario where the Quattro fails. I’m now planning to installing a 3-way transfer switch (Shore, Generator, Inverter) that allows Shore or Generator to be routed around the Quattro.
Tom avatar image
Tom answered ·
Why don't you just turn off charging buy using the Victron Connect App. This way you can have just inverting or just pass though.
