petajoule avatar image
petajoule asked
MPPT 250/85-MC4 shortcut current 30A absolute?
MPPT 250/85-MC4 has 3 (pairs) of MC connectors - I call them 3 ports.
Spec sheet says max 70A from PV, not more than 30A per port.
So if I have just one of the ports connected (others will remain free), but the current is plusminus 30-35A (there is an 5S3P array connected to it), to be on the safe side, I should use a Y cable to connect to two MC4 ports on the MPPT?
MPPT Controllers
Murray van Graan avatar image
Murray van Graan answered ·
Absolutely yes. The 30A is the connector limit, it’s always best to try and distribute it best you can.
petajoule avatar image petajoule commented ·
Thank you. In Germany the specified limit per connector is 30A with 4mm² and 43A with 6mm² - nevertheless I will distribute the ~30A current on two ports of the MPPT as that is a too close call otherwise.
