Andrew945 avatar image
SmartSolar 100|15 load connected to Phoenix inverter fails
Have a 100|15 SmartSolar charger charging a 12v battery pack. Charges fine. Phoenix 12v | 350w connected to the load ports disables the load output. Disconnect the inverter and cycle power the SmartSolar charger; load output goes to 12v as expected. Connect Inverter directly to the battery, inverter works fine. What could be going on? Thanks so much for any help!
smart solar set-up help
JohnC avatar image
JohnC answered ·
Hi Andrew. Victron don't recommend running inverters from the load terminals. Perhaps especially their own, which are heavily built and with a lot of capacitance aboard. Even when turned off, just hooking them up can easily exceed the capability of the load terminals. It often comes with a spark, such is the speed at which this happens.
There are workarounds, like a relay setup to the batt connection. I wouldn't bother myself, but your choice whether to head there if the load V-protection is an issue for you..
1 comment Share
Great explanation. Thank you very much.
What you need is this cable to connect the remote contact of the Phoenix to the load contact of the MPPT:
https://www.victronenergy.com/cables/inverting-remote-on-off-cable
2 comments Share
I wasn't aware that gizmo existed. Like a relay-in-a-cable. :)
Ray_mont avatar image
Ray_mont answered ·
Hi @Andrew945
a very rough calculation
the inverter will draw at 12v 29 amp (350 watt / 12volt)
the max output on the load connection is only 15 amp
that’s why the SmartSolar Will disconnect the load.
Ray
1 comment Share
