JARENO avatar image
JARENO asked
multiplus 1200VA
le voyant alarme en facade du multiplus s'active frequemment alors que le parc batteries est chargé.j'ai bien entré avec VE config les valeurs de tension deconnexion batteries 24 V (12 batteries stationnaires 2 V tubulaires OPZS )
Hi @JARENO
If you connect with Victron Connect, you can also see more detailed led-codes and see what voltages and currents are there. This is usually enough to trouble shoot what is going on.
