rainerb avatar image
rainerb asked
Venus GX Digital Input - dbus command syntax
does anyone know the exact dbus command, in order to read out the State of Digital Input 4 of a Venus GX device? I use a bash script with a few other (working) dbus commands but I can't find the exact syntax for the inputs.
I found the following in the "Modbus TCP Register list", but still don't know the command to address a specific Input:
I tried this and a lot of variations dbus -y com.victronenergy.digitalinput /State GetValue
(By the way, the Input is working and shows its state on the Remote console).
Thank you
Rainer
Venus GX - VGX
Ole Saether avatar image
Ole Saether answered ยท
Try:
dbus -y com.victronenergy.digitalinput.input04 /State GetValue
rainerb avatar image rainerb commented ยท
Hi, thank you. That is what I was looking for, it works...
0 Likes 0 ยท
markussi avatar image
markussi answered ยท
hello,
i search the correct Input mapping for the digital Inputs of the venus gx via Modbus.
I use a Siemens Logo, at this device i have no "dbus -y com.victronenergy.digitalinput.input04". I can only use Adress and Unit ID. Which Unit ID i should use for the digital Input 1-4?
Other Data (for example the SOC on 843 and Unit ID 0) works fine.
Thank you,
Markus
4 comments
Ole Saether avatar image Ole Saether commented ยท
@MarkusSi
Go to https://www.victronenergy.com/support-and-downloads/whitepapers
and download the document Modbus-TCP register list. In this document it is described how to obtain the Unit ID.
0 Likes 0 ยท
markussi avatar image markussi commented ยท
@osaether
in the Modbus-TCP Register list ist no extra Unit ID for each of the 5 different digital Inputs. In the Register List is no Unit ID for com.victronenergy.digitalinput.input
What are the different Settings for Input 1 vs. Input 2?
0 Likes 0 ยท
Ole Saether avatar image Ole Saether markussi commented ยท
@MarkusSi Have you checked the complete document I mentioned above? It is described under "Note on finding the modbus Unit ID" at the bottom of the tab "Unit ID mapping"
0 Likes 0 ยท
mvader (Victron Energy) avatar image mvader (Victron Energy) โ™ฆโ™ฆ Ole Saether commented ยท
Hey both, to find the unitid, there is a page in the GUI now. See in the GX Modbus-TCP manual:
https://www.victronenergy.com/live/ccgx:modbustcp_faq
Also, if ever you want to see the source code of the mapping, and our changes to it, see here:
https://github.com/victronenergy/dbus_modbustcp/blob/master/attributes.csv
(same file is on your GX device)
best, Matthijs
0 Likes 0 ยท
