ncrncevic avatar image
ncrncevic asked
Smart Solar for 350w monopanel
Hello
I would like to upgrade my boat and would like to buy a solar panel
I decide to buy a LG solar mono panel 350w for my boat
on my boat i have 2 bateries, maybe i would like to buy one more
they are all AGM
Now i am looking for a Smartsolar
but i dont now the size to buy or witch model ?
Can you please help me
Regards
smart solar set-up help
wkirby avatar image
wkirby answered ·
I'm going tro assume that your batteries are 12V, your system Voltage is 12V.
So, with 350W of PV power, you'll be charging with around the same power.
350W / 12V = 29.2A
You need a charge controller that can charge at 30A to be able to make the most of your solar panel.
The MPPT100/30 will be perfect for you. This charge controller's output will be maximised with 350W of solar on a sunny day.
If you have even the slightest idea of adding more panels in the future, then you'd be better off considering a larger charge controller.
ncrncevic answered ·
Thank you for your help
i can put only one panel on the boat
the system is 12V
can i charge only one batterie or i can charge all 2 or 3 maybe in the future
Regards
All, as long as they're the same type/model and wired in parallel. Otherwise you need to add a DC to DC charger to handle the battery diferences
Andreas Nicolet avatar image
Andreas Nicolet answered ·
Im curious what would happen if I use a 75 / 15 instead? Will it just limit the current flow or will I damage the unit?
Just limit the charge rate, so long as VOC doesn't exceed 75V, even in winter.
jordan-de-geus avatar image
jordan-de-geus answered ·
i have a lg 350w panel 2 of them. Both are hooked to their own 100/30 smart solars without any troubles. I cary a third smart solar onboard my boat in the event of a unit failure.
