Is there any way to configure my easysolar 48/5000 without VE.direct to USB?
You'll need the VE.Direct to usb adaptor to change settings in the mppt, but VRM can manage firmware changes in the mppt without it. And you'll need to pull the existing cable from the mppt to do it.
That's the opposite way round for the Multi, and an 'anomaly' in the system..
If you have an internet connection at the CCGX you can use Remote VeConfigure via VRM portal to download/upload config files from/to the Multi.
But I would recommend you to update the firmware of the Multi and that can only be done with a MK3.
10 People are following this question.
Offline updater for assistants in VE configure 3
How to set MultiPlus to prioritise solar power before shore power, but shore power before batteries?
Phoenix Multiplus 24/3000/17 Software version 1812144 connection problem with MK2.
7kW Solarinstallation coupled to grid without feeding to it but charging an 40kWh lithium battery
