eneko avatar image
eneko asked
Mixing 12V and 24V inputs in MPPT
Hi, I have 4 solar panels working at 24V connected to a BlueSolar MPPT 75/15, with a 12V battery. I have a 12V small wind turbine and I wonder if it is possible to connect it directly to the same regulator or if it is mandatory to use another regulator.
Thanks in advance!
MPPT Controllers
wkirby avatar image
wkirby answered ·
You should use a separate regulator for wind otherwise the PV and Wind will be backfeeding or fighting each other. A 24 PV array may damage a 12V turbine.
Also, take precuations when connecting a Wind generator to a MPPT designed for Solar. The open circuit Voltage of electromagnetic generators can excess the maximum allowed Voltage of the MPPT and damage it. You may not get a good yeild from a solar MPPT supplied by a wind generator, the MPPT scan will very likely stall the turbine.
