blond2silver avatar image
blond2silver asked
Multiplus parameter for "shutdown on SOC" when CCGX is gateway, and BMV-712 is battery monitoring source
Hello, Does anyone know if by enabling, and setting the Multiplus "shutdown on SOC" is integrated with the CCGX or Venus as a gateway, and when the BMV-712 is the battery monitoring SOC source?
For example, I'd like to enable the Multi parameter for "shutdown on SOC" to 20/20 without configuring the Multi capability as a battery monitor, which would be redundant, and in that the BMV-712 is the battery monitor source of choice.
You have to activate the battery monitor in the multi and the "sync SOC with VE.Bus" option at the CCGX.
PeterM avatar image PeterM commented ·
"sync SOC with VE.Bus " - I dont have that option - I have only the following - will "automatic" sync SOC or must I used BMV on VE Direct?
blond2silver answered ·
Thanks M.Lange... Understood, albeit the BMV-712 is a more accurate battery monitor in that I do have significant DC loads that the Multiplus I would think just can't monitor - in othewords, the Multi's battery monitor is designed to calculate SOC for what the Multi consumes - is that correct? So the "syncronize VE.bus with SOC" is on already. Hopefully this means the BMV-712 is the source battery monitor for syncronization, else the SOC parameters within the Multiplus will be in-accurate. Is that a correct statement?
That's correct the SOC of the selected battery monitor will sync with VE.Bus and overwrite the Mults internal battery monitor.
