Gerald Williams avatar image
Gerald Williams asked
DVCC with Ve.can Blue Solar MPPT
Hi. I have a simple off-grid, no assistant setup:
1x Quattro with gen connected to ac1, 2x BlueSolar 150/85, CCGX, BMV-700.
I have a situation where if for some reason the generator starts on a sunny day then my battery charge current is way too high.
DVCC sounds like the answer to this situation.
Will a fututre software update allow the BlueSolar 150/85 to work with DVCC or do I need to buy new MPPT controllers?
If I enable DVCC without compatible MPPTs, will it still current limit the generator/quattro in the example above using the BMV700 as a battery current reference?
Regards
Gerald
DVCC
Hi @Gerald Williams
I'm guessing these are the older 'square case' MPPT's?
If so I don't think they will support this.
You could wire the enable signal through the relay of the BMV or a relay of the Quattro to switch off the MPPT's when (BMV) current get's too high, or (Quattro) when AC-in is available.
You can also command the Quattro to lower charge current when (BMV) measures it too high.
