hechtimnetz avatar image
hechtimnetz asked
Power (W) of PV drops mppt 100/50 under load and low battery
Hi, i have 4 PV on my roof and this morning i check at the victron connect app, here it shows up that i get around 168W but it drops every 10 seconds to 0W for 3 seconds. My battery is at this time on low voltage at 10,8v and i use the victron multiplus. So the multiplus shows up the alarm LED because of low voltage and i charge a laptop. Is it possible that the low voltage and charge the laptop cause this issue that the W of the PV drops in the mppt?
MPPT Controllers
elf avatar image
elf answered ·
@hetchtimnetz Sorry you haven't had a reply to this. Some time now so I hope you have resolved it and could post an update
