good morning
if i connect two inverter in a parallel , if one fails both inverter shutdown is there any reason for both inverter turn off.is it possible to run if one fails other inverter alone run without reset the settings. thanks in advance.
good morning
I have a client who needs a secure uninterupted feed .
he needs two inverters to be connected to the load but if the one fails the other should take over and support the load.
in other words the one inverter should be the backup to the other inverter.
Can this be done ?
13 People are following this question.
