serdarzbk avatar image
serdarzbk asked
message format for VE.Direct protocol
hi,
I try to understand the communication of Bluestar MPPT 70/15 with external microcontroller system (e.g. arduino) with hex protocol
I received some exmaple codes from open source page of victron.
But there is a main point that i could not understand.
i could not undestand the main message format such that:
get MPPT Charger Volt ":7D5ED008C\n"
: is starting colon
7 is get command
D5ED is adress of charger voltage 0XEDD5
008C what is this phrase?
\n add of command
another example:
get MPPT charger current ":7D7ED008A\n"
: is starting colon
7 is get command
D7ED is adress of charger current 0XEDD7
008A what is this phrase?
\n add of command
i think everything will be clear for me if i can learn this part.
best regards,
VE.Direct
