HI All, below is the graph of solar power plant 6kw@48 V, on clear sky there is drop multiple times , is it due to the fact that another power source is connected in parallel , to the same bus bar rectifier which takes 220V AC and convert it into DC 48V. what should i do to make this graph as per standards
![1721393876984.png](/storage/attachments/93151-1721393876984.png)
