roemerdesign avatar image
roemerdesign asked
Multiplus Compact 12/1600/70: AC dropouts when battery is fully charged
I have the problem that the 230V/AC output is interrupted for a short time during charging and when the full capacity of the connected batteries is reached, thus switching off the connected computer.
The devices are as follows:
- Multiplus Compact 12/1600/70
- Batteries 2x Liontron 200Ah LiFePo4 12,8V with built-in BMS
- Consumption: 1 Mac Pro and 3 hard disks, consumption approx. 100 - 250 Watt
I have tested it with an absorption voltage of 14.4 and 14.1 volts on the Multiplus, it is always the same problem.
What am I doing wrong or what can I do to fix it?
Thank you very much for your help,
Axel
Translated with www.DeepL.com/Translator
Hi @roemerdesign
Without more information, I'm guessing:
-Battery disconnects due to cell overvoltage internally
-Multi sees too high DC voltage and / or High DC ripple and shuts down.
Try an even lower charge voltage (13.8?) for a while until the batteries are properly balanced.
roemerdesign answered ·
Hi, Daniel,
thank you very much for your answer! I don't think the problem will occur at even lower charging voltages, because even at 14.1 volts just before reaching 100% charging capacity, the voltage quickly rose above 14.1 volts. I took this from the values of the Bluetooth interface of the battery via the mobile phone.
Well, in a few days I finally get the BMV-712 with shunt and hope to understand the problem better.
Is there a device from Victron Energy that causes the Multiplus to stop charging shortly before reaching 100% battery capacity? Would this be possible with the BMV-712 via the VE.Bus?
I hope my questions are not too stupid...!
Thank you very much for your effort,
Axel
Hi Axel
The problem is that the batteries disconnect, just charge to a lower voltage.
