stellar-energy avatar image
stellar-energy asked
Smartsolar RS450/100 + MPPT 250/70 on Multiplus II GX grid feed in problem
Hello!
vrm id: vc0619ab3d554
Changed from SolarEdge to SmartSolar + MPPT on DC-bus today.
Charging the battery work great, however as soon as the batteries are full, the system stops the PV panels, releases power from the battery to the grid for a bit, and then start up the PV panels, rather then feeding back the PV DC power to the grid. Not really what we want ;-).
What I see is that the setting feed-in limiting is set to yes. We can not find anyt way to change this. Re configured the ESS assistant and checked all settings to no avail.
Hopefuly someone can sort this out for us?
Multiplus-II
