I am using VictronConnect v5.11.
If I go into Settings > Battery for my SmartSolar MPPT controller (100/30) and switch off Charger Enabled I get the warning message โCharger will be disabled and battery will stop charging. This is intended for maintenance purposes only.โ
Is it detrimental to have the solar panels connected (in full sun) but charging disabled and, if so, (a) what problem(s) will arise if I do this and (b) is there a safe time period before the problem(s) will arise?
Thank you.
