bobcat avatar image
bobcat asked
Skylla-i Rotary Switch question
I wish to control my Skylla-i via CAN messages. In VE.Can-registers-public.pdf, it states:
  1. Some charger models have physical switches to control the charging algorithm, for these models the vregs can only be queried to find the actual settings (e.g. the Skylla-i charger has a rotary switch and dip switches, when the rotary is set to any position other than CAN control most of the vregs will be read-only).
The Skylla-i manual does not show a position for "CAN control". It does say not to use position 0. Is that the one? Why is it not to be used?
Also, does the Skylla-i have DC Load output settings?
VE.Can
