sjones avatar image
sjones asked
Loud hum from Victron Multiplus 12/3000/120
We have a solar system in our Airstream trailer installed by an AM Solar dealer. Lately after we get to our next site and hook up to shore power, there is a loud hum coming from the Victron Multiplus 12/3000/120 inverter as it works to top off the batteries. The hum only lasts for a short while and stops once the system achieves "absorption" I think.
Any ideas of what I can check and whether or not this is something serious?
Thanks
Jesse avatar image Jesse commented ·
I'm getting a similar hum in a new 12/1600/70 multiplus (about 200Hz?) as absorption completes and it persists while in float with low currents (2-3 amps) into the battery so it's not actually doing anything.
There's no resonance, mine's still sitting on carpet while I test it out. Its too noisy, I'd have to disable battery charging most of the time.
Hi @sjones
You could try to lower the charge current.
Usually when a unit makes too much noise, its because it's mounted on a panel that is not rigid enough and resonates with the unit's vibrations.
sjones avatar image sjones commented ·
Thanks Daniel. The unit is mounted to the floor of my Airstream travel trailer. The floor is quite rigid, so that is not a possibility.
How would I lower the charge current? All equipment is made by Victron.
As mentioned, the vibration/noise is only when shore power is first connected. After a few minutes it fades out.
Thanks,
Steve
kai avatar image kai ♦ sjones commented ·
Re: charge current, you'll need to use the VEConfig software with a MK2 or MK3 interface hooked into the multiplus.
Resonance issues can be solved in a number of ways - increase stiffness/weight is one method, soft mounting to "soak up" the vibration is another. Unless you have a specialist on hand to advise, imo its a case of trying different solutions until one sticks - its likely to be very dependent on the physical geometry of the mounting location, mounting orientation and how the mounting location is connected to underlying structures.
