jannichl89 avatar image
jannichl89 asked
Two different size multi plus in parralel
Hi there.
I would like to ask if it's possible to run two different size multiples in parralel operation with the communication cable between?
I have an multiples 1600VA, but would like to run it in parallel with a multiplus 3000VA.
both are 12 volt
Thank you
anthony avatar image
anthony answered ·
This is not permissible, the two units must be the same size units using the same firmware. Please read more on this here: https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
Elimac avatar image
Elimac answered ·
As Anthony said, it is not possible. But you could consider using cascade configuration. See:
https://community.victronenergy.com/questions/674/two-multiplus-inverters-best-aproach.html
Note: at the time I wasn't aware of what split phase really means. Splite phase is different from AC out independent lines.
