dennis-weber avatar image
dennis-weber asked
Using Node Red to set different MultiPlus current limits on a split phase system
My motorhome has an inverter generator capable of 67A with a regulated voltage output of 120 Volts. If I connect the generator to L1-N of a Victron autotransformer, the output voltages will remain within range A of ANSI C84.1 (108-126 Volts) between no-load and full load. The continuous current rating of the L2-N winding is 28A. I configured the MultiPlus compact inverters in a split phase configuration to limit the neutral current (below 50A). If I limit the input current to both inverters to 28 amps to protect the auto-transformer from overload, the max generator output will be limited to 56A (16% reduction). I would like to automatically set the current limit on L1 inverter to 39 amps and the L2 inverter current limit to 28 amps when connected to the generator. Is this possible in node Red?
Node-REDcurrent limit
