offgridtas avatar image
offgridtas asked
Help with API
Hi.
I'm trying to extract some SoC information from the Cerbo using a Raspberry Pi running Python. I'm able to get a token but when I try and use the token it is returning "errors":"Login required","error_code":"invalid_credentials"
Surely if it's giving me a token, the credentials aren't invalid.
Any help greatly appreciated.
import requests
USERNAME = 'my username'
PASSWORD = 'my password'
# VRM API endpoints
LOGIN_URL = 'https://vrmapi.victronenergy.com/v2/auth/login'
DATA_URL_TEMPLATE = 'https://vrmapi.victronenergy.com/v2/installations/{installation_id}/stats/latest'
def get_auth_token(username, password):
    # Authenticate and obtain an authorization token
    headers = {'Content-Type': 'application/json'}
    payload = {'username': username, 'password': password}
    response = requests.post(LOGIN_URL, headers=headers, json=payload)
    if response.status_code == 200:
        token = response.json().get('token')
        return token
    else:
        print(f'Failed to authenticate: {response.status_code} - {response.text}')
        return None
def get_current_soc(token, installation_id):
    # Get current State of Charge (SoC) using the obtained token
    headers = {
        'Authorization':f'Bearer {token}',
        'Content-Type':'application/json'
    url = DATA_URL_TEMPLATE.format(installation_id=installation_id)
    response = requests.get(url, headers=headers)
        data = response.json()
        soc = data.get('battery', {}).get('stateOfCharge')
        if soc is not None:
            return soc
        else:
            print('State of Charge (SoC) not found in response.')
            return None
    else:
        print(f'Failed to fetch SoC: {response.status_code} - {response.text}')
        return None
if __name__ == '__main__':
    installation_id = 'my installation ID'
    # Authenticate and get token
    token = get_auth_token(USERNAME, PASSWORD)
    if token:
        # Get current SoC
        print(token)
        soc = get_current_soc(token, installation_id)
        if soc is not None:
            print(f'Current State of Charge (SoC): {soc}%')
        else:
            print('Failed to fetch State of Charge (SoC)..')
    else:
        print('Authentication failed.')
api
