jf1976 avatar image
jf1976 asked
reversed polarity ac out
hello there, im planning to acquire a Multiplus II 48/5000 to use it as a alternative source for some loads in my household when the grid is off - connected to set of batteries - without solar panels at the moment. one of the important load is the gas stove - modern gas stoves need nowadays a fixed polarity to work - does anyone know, if the multiplus im willing to buy offers the fixed polarity at the ac out (does not reverse the polarity at the ac out)- the one that delivers the power when grid is off?? apparently, not every inverter charger available on the market, can offer it - i want to be sure, Multi II does.
Multiplus-II
thesmok avatar image
thesmok answered ·
I think what you mean is a grounded Neutral line. The gas equipment needs a grounded Neutral for the flame sensor to work properly.
The Multiplus has a ground relay that connects the AC Out N to Ground while in Inverter mode, so your gas stove would continue to work. The only requirement is that you should connect the PE wire to the Multi.
jf1976 avatar image
jf1976 answered ·
thanx a lot!
