Greetings, Victron. I'm just getting started with Venus OS Large 3.34, and found that checking for FW updates offers older 3.33 as an "update" to newer 3.34. This seems like it should not be the case. Have I missed something basic?
Screenshots:
Screenshots:
Latest available Venus OS large is v3.34
Latest available Venus OS normal is v3.33
Does that explain it?
See change log for the reason of the difference
Hi @abeness
The reason is that your installed version is 3.34 Venus OS Large. If you set "Image Type" to "Large", you will get 3.34 as a result.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
103 People are following this question.
Pi install with 7 inch touch screen, any change of higher resolution now that CANvu is out?
Digital Input for a tank monitor? dbus? Anyone working on it? I've got $100 to start a fund.
Building a Raspberry Pi with Venus OS
Raspberry Pi Venus OS local file system question
Help with Raspberry Pi with Expander Pi (for RTC and tank levels)
