chiefsen avatar image
chiefsen asked
Argo Diode Battery Isolators-voltage drop-AGM(14,4V) Bat-Charger sett on 14,8V
Hi
I want to instal the Argo diode battery isolator 80-2 SC between the Engine Batery (115AH) and House-Batery (2x110 Ah in Paralel) on a Sailboat.
Charging from an alternator....The compenstaion-diode will increas the output voltage as a compensation for the voltage drop of the Argo diode battery isolator 80-2 SC....so far all clear.
The Sterling Shore-Power charger have no Comp-outputt for the compansation cable. And have only 2 output-settings:
AGM Bateries=14,4 V
Lead Accid=14,8 V
voltage drop of the Argo diode battery isolator 80-2 SC is approximately 0,3 V - 0,45 V.
Is it OK to set the chager on 14,8 V ...and after the diode, there sholuld be 14,4!?!?
Or just be practical...mesure the inputt by each of the settings and then choose.
Thank you.
voltageisolators
Justin Cook avatar image
Justin Cook answered ·
@Chiefsen, what Sterling charger do you have? We're a Sterling distributor and every unit I'm aware of has multiple charge profiles including (usually) a custom option.
Other than that, definitely err on the side of caution with your AGMs, but yes, I'd measure your actual output and choose your settings from there.
chiefsen answered ·
@Justin Cook, its a Sterling 1230 (12V, 30 A) charger. here is a photo. I will measure the output before and after the isolator... before switching to 14,8 V. Thanks.
Ow wow, that's some vintage equipment there, I'm afraid that predates my experience... and I stand corrected about multiple charge profiles! Best to continue as discussed then, and measure your actual output and adjust accordingly.
