Martin Gasthuber avatar image
Martin Gasthuber asked
tail current in ESS config
the latest MPPT firmware starts supporting a tail current limit for transitioning from absorption to float for charging. I've looked for this a long time... but haven't found the corresponding settings once the MPPTs are 'remote controlled' in a ESS config (Multiplus is also charging). Did i need to wait a little longer until this feature is supported in an ESS config, or is it already in ?
best regards,
Martin
battery charging
Janek Plathe avatar image
Janek Plathe answered ·
I have the same question,
Would like to adjust the tail current in an ESS Setup with multiple MPPTs.
