k10 avatar image
k10 asked
Cyrix and BMV712
I have a Cyrix connecting my starter battery (MB Sprinter) to the house battery and have a BMV712.
I use an AC charger to top up the house battery before a trip
Battery reads 13v +
During trip main load is fridge 6a @ 12v
The battery voltage as expected goes down over the trip
however when driving the battery is not charged and BMV shows 100% SOC always !!!!
TESTING - output of Cyrix is 13v+ - shunt seems to not allowing charge to get to battery
Cyrix Battery Combiner
wkirby avatar image
wkirby answered ·
My initial thought is that the shunt is in the wrong place in the circuit or is not connected correctly.
Is it possible to show a wiring diagram of how these things are connected in your van?
k10 avatar image
k10 answered ·
HI
I have been on vacation so sorry for not replying earlier
Testing with engine running and house battery discharged :
1) If I test voltage between POS on the house battery and the ground when NEG disconnected on house battery I get 13V PLUS = output of alternator
2) If I test voltage between POS on the house battery and the ground when NEG connected I get House Battery voltage (ie 11V)
Charge is not getting to house battery
here is the basic layout
k10 avatar image
k10 answered ·
OK I managed to get the Cyrix to charge the battery now
It seems there is an order in which the batteries need to be connected
The status light was indicating ALARM - the Cyrix is mounted under the seat so I did not know the status until I removed the seat today
I disconnected everything and re connected and it went from ALARM to DISENGAGED
Then I started the engine and it went to ENGAGED and BMV indicated a charging voltage 13v PLUS
