Hi. Hoping for some remote support. Following a firmware upgrade to 2629_552 my GX restarts about every 2 minutes. The GX is running v3.33. It seems the inverter is working fine - there may be a problem with the GX board.
Rolled back to last know working version 508 - no change, GX reboots. Settings file reloaded with last known working version, GX reboots. Rolled back nanopi VenusOS version to 3.10 and still reboots. Looking like a hardware fault.
The GXcan be deliberately set to reboot when VRM connection is lost. Check you don't have something crazy set there..
I disconnected Grid and ACOUT from the Multi to see if there was a wiring or grid fault causing the reboots. Even on battery the GX is rebooting - every time the unit reboots it sends a new alarm to VRM for loss of grid. I think there's a hardware problem.
Looks like an alarm relay is triggering a fault condition causing the reboot. Does anyone know where the alarm relay is on a Multi-IIGX?
117 People are following this question.
