I have a MPPT RS 450|100 Tr.
Now I'm trying to make a widget on the VRM portal to view Voltage, Current and Power.
On the dashboard I can see the current, but not in the widget I try to make.
Any idea why?
Thanks.
Any idea why?
Thanks.
Hi @Diederik
I have the feeling that there are two "channels" for data reporting that are sent to VRM.
One is the one used for Dashboard and relates with the Realtime updates.
And another, a big packet, used for database storage and from where the information are taken for widget related display.
So you may see the MPPT current info on Dashboard (live), but for widget configuration / display, the MPPT current info may not be present / sent for database storage, despite the fact that you can select it on widget design.
They may need to sync what they collect with what they can display and update the items for drop-down selection.
For example, I have a Multi RS, with somehow similar configuration on solar configuration like your device, but I don't have the selection on widget creation the current info.
Alex
44 People are following this question.
