Tim avatar image
Tim asked
2 x 60 watt panels in series with Victron BlueSolar MPPT Charge Controller 12/24 - 40A (2013 model) possible?
Hi guys,
I am hoping you could help me out. I have 2 x 60 watt solar panels of 12 volt (Voc 22,18 per panel, see below) and an AGM battery of 12 volt. I will connect them in series while I have to cover quite a distance from the panels to my shed where the charge controller, battery etc is. This makes a Voc of 44,36, right? I already have an ‘older’ Victron MPPT controller (40A). See specs below. I am not sure though how to interpret the numbers? Can I use this controller with my panel setup? My doubts are with the ‘Max PV open circuit array voltage’. How do I read this? Is this based on my battery (12V)? Or based on how I wired my panels (24V)?
Hope you can help!
Regards,
Tim
MPPT Controllers
Do you have the exact model number of your MPPT?
Tim avatar image Tim Guy Stewart (Victron Community Manager) ♦♦ commented ·
Hi Guy, yes I have. See below.
Paul B avatar image
Paul B answered ·
The Answer is NO as Max O/C on a 12 volt system is 28V
The full manual can be downloaded here
https://www.victronenergy.com/upload/documents/Manual-BlueSolar-MPPT-Charge-Controller-12V-24V-40A-EN_FR_DE_ES.pdf
