thtruck avatar image
thtruck asked
Multiplus 24/5000/120 makes hard humming sound with and without load
Before i bought this 24/5000/120 i had a 24/3000/70-16 and that one didn't make a sound until there was some load on it but the 24/5000 starts to humm hard when i just switch it on without any load on. It is really dissapointing because i also sleep in the same aea. What can it be and what can be done with it?
Did you upgrade the dc wiring etc to match the new inverter?
thtruck answered ·
Yes. Over a distance of 1.7 meter to the powerin 70mm2 is sufficient according the manual. I think it is the transformator which is too loud. It produces also other sounds as clicking and stuff.
thtruck answered ·
I still have the 24/3000/70 and i will check if that one is still silent.
Alex Pescaru avatar image
Alex Pescaru answered ·
Hi @THTruck
If you can and want to open it, maybe the transformer fixings are off from assembly, transport, etc and you can correct them.
The joy of LF inverters.... I have some APC UPSes with the same problem...
Alex
thtruck avatar image thtruck commented ·
Thanks you for your comment. The Multiplus is going back to Victron's dealer to check things out. I'll wait for the outcome.
