Hi, i have a setup where it was wanted to adjust ac voltage up.
(From 230 volt, up to 240 volt.)(3 phase quattro 10k and quattro 15k setup)
but when do, we now and then after peak loads get ve bus error #5, high voltage error.
Can it be that the ve configure settings allow up to 245volt is not fully implemented in alarm Limits in firmware?
We did not see this error before we adjusted the volt output.
and VE configure says ok up to 245 volt.
this maybe would need a new firmware?
