not charging or accepting any power from my generator/shore power.
Need more details. What inverter/charger? Is there a cerbo in the mix? What type of installation? (I assume mobile since you mention shore?) Do you have a mk3 available?
I have Quattro 5000 Watt 48 Volt Inverter. When it is cloudy I turn my generator on and it charges the battery bank and helps run the AC as it is charging. I turned it on and for some reason it showed no power on the GTX. I have power coming in, but the invertor is not accepting it It would always work, not sure what happen.
If you have an mk3 you can use victron connect or ve.configure to see why the generator power is being rejected.
Ok, i will check the settings when I go back next weekend.
Other then settings do you think it could be anything else?
If you have a gx and the system is connected to the internet you can check remotely.
Check is AC ignore or virtual switch is configured (with an mk3 if on site).
86 People are following this question.
