towpro avatar image
towpro asked
MPPT common Negative
My RV (trailer) has the negative side of the solar panels connected to the RV chassis and the positive wire is a home run to the location where I want to put my 100/50 MPPT solar controller.
Can I use the 100/50 MPPT controller with a solar panels negative output tied to the same common negative (chassis) that the negative battery is connected to?
MPPT Controllers
