My CCGX is not seeing my MPPT 100/50 when connected via a VE Direct cable
@bennettmvc, there are several conditions which can cause this; the immediate one which I'd check first is: is the cable in good condition? Check for any nicks in the insulation, hard bends that may have broken the wires inside, etc. Then check both end of the connection, make sure that the pins on the MPPT and CCGX are oriented properly (the pins can often become a little bent, which may prevent the cable from inserting fully) and that the ends of the cable are in good condition and securely inserted into the VE.Direct ports. You may also try moving the cable from the MPPT to a different VE.Direct port on the back of the CCGX.
I'd then check that the firmware on both the MPPT and the CCGX is fully up-to-date, and then, finally, after all the above has been checked and found to be good, restart the CCGX (Menu > Settings > General > Reboot?) and see if the MPPT comes back online.
If it's still not showing up after all that, it may be time to contact the distributor from whom you purchased the equipment; it's rare, but it does happen on occasion that one of the VE.Direct ports goes out on the CCGX.
Iโm stumped!
The only one missing combinations I can see is possibly a bad cable, it reads like you swapped the ve.direct ports with BMV at the CCGX end, but not necessarily swapped the cable itself at both ends?
That would explain the bluetooth dongle working.
Given all those isolations the next thing I would try is another MPPT, and/or your MPPT on another CCGX. Your dealer should be able to help with that further test if you don't have those available.
12 People are following this question.
