I have a pack of Nissan Leaf batteries connected to my multi and I like to change the charge voltage to 16.8 volt. Is there a way to do that?
Hi TexDoe, Did you get anywhere with upping the voltage a little on your multiplus? Im running a 12/800 off a bank of leaf cells setup in 4s and currently max charge is 16v, like you im wanting to get to 16.8 a I believe im missing out on quite a bit of capacity. When I was checking compatibility I saw the inverters max voltage wa 17 so was hoping the charge settings would go up a bit higher than 16.
Cheers, Mike
11 People are following this question.
